Activity › Forums › Apple Final Cut Pro Legacy › OT engineering question
Posted by Matthew Mcnulty on February 14, 2007 at 10:47 pmhave a client ask me this question… how far of a cable run is possible if i have a 1080p video playing over it? i asked what kind of cable? he retorted you tell me… ok so… he has a av system in his corporate HQ or soon to be HQ and is looking to install 1080p monitors here and there… he/we want to know what cable technology is best for a potential distance of about 375 feet… hdmi? hd/sdi? network cable(cat5 or 6)… if you tell me wrong forum point me to the proper one… thanks!
Gary Adcock replied 19 years, 7 months ago 7 Members · 6 Replies -
Steven Gonzales
February 15, 2007 at 4:27 amI believe there are amplifiers and repeaters available, so it probably depends on your budget. Also, the quality of the receiver chip will have an effect on marginal signals.
It may be hard to get a simple, definitive answer.
Arnie Schlissel
February 15, 2007 at 5:41 amYour cable company can send a 1080p signal many miles. Your satellite company is sending it from the earth, to outer space, to your home. They both have specialized equipment & codecs to help them do this. Tell your client that if they have the will (and the cash) there’s no limit to how far they can send a signal.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Tom Matthies
February 15, 2007 at 2:16 pmHD-SDI should be able to cover that distance without any issues using the proper co-ax cables and DA’s. I don’t believe that HDMI can cover the same distance without repeaters but I could be wrong. There are also fairly high-end fiber optic converters available if quality is a big issue. The networks also use a combined optical/electrical hybrid “tri-ax” cable when running long camera runs at sporting events. Expensive but possible.
If absolute quality isn’t the issue, you could install HD modulators/demodulators and run the signal thru an RF cable from a central location. For monitoring content, it should be fine.
Many ways to do it. Just depends on the necessary quality issues.
tom -
Walter Biscardi
February 15, 2007 at 2:46 pmI would contact a local engineer or engineering / repair shop. We have a few here in Atlanta and they could certainly tell you what you need. Look up a Panasonic or Sony Broadcast Authorized repair center in your area and give them a call. They’ll usually chat on the phone with a question like this for free.
We have 75′ runs of HD-SDI in our shop with no signal degredation using those. 375′ might require some sort of amplification.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Gary Adcock
February 15, 2007 at 3:53 pm[Mowbray] “how far of a cable run is possible if i have a 1080p video playing over it? i asked what kind of cable”
HD/SDI cables max at about 300ft without amplification – just like any BNC cable run that is properly shielded.
“1080p monitors here and there… he/we want to know what cable technology is best for a potential distance of about 375 feet…hdmi? hd/sdi? network cable(cat5 or 6)”
Fibre is 22 kilometers
HDSDI gives the longest “standard” cable runs, at about 300 ft.
HDMI cables max’s out at 3-5 meters
CAT 6 is not fast enoughFYI — Noone transmits a 1080PsF signal that I know of, just 1080 60i,
You only get that PsF signal from a tape deck or Bluray DVDgary adcock
Studio37
HD & Film Consultation
Post and Production Workflows
