Activity › Forums › Apple Final Cut Pro Legacy › OT: dubbing over firewire???
  • OT: dubbing over firewire???
    Posted by Paul Nevison on August 16, 2005 at 10:50 am
    hey there,
    a slightly off topic question here. I need to make some DVCAM dubs of some camera tapes. We dont have multiple decks to do this inhouse. Is it possible to hook up my sony DSR 1500 to a camera via firewire and dub either to or from the camera? our deck doesnt have an analogue option (its all SDI – but our cameras, which are pd-150s and a pd-x10 dont have SDI)
    is this possible or can someone think of another option.
    thanks
    G5 DP 2.0
    2.0G RAM
    OS 10.3.8
    QT 6.5.2
    FCP HD 4.5
    CineWave 4.7
    Cinewave RT Pro
    Pro Digital Plus & Pro Analogue BOB
    Paul Nevison replied 21 years, 1 month ago 2 Members · 4 Replies
  • Thaxter Clavemarlton
    August 16, 2005 at 11:08 am
    It will work perfectly going either direction.
    There will be no generation-loss.
    If you go FROM a camcorder TO the Deck, it MIGHT be possible to retain the tape’s Timecode as well (if the deck has that menu option).
  • Paul Nevison
    August 16, 2005 at 11:10 am
    thanks for the reply,
    is it as simple as connecting the camera and deck and crash recording? or will there be menu options to set up?
    G5 DP 2.0
    2.0G RAM
    OS 10.3.8
    QT 6.5.2
    FCP HD 4.5
    CineWave 4.7
    Cinewave RT Pro
    August 16, 2005 at 12:57 pm
    [paul nevison] “is it as simple as connecting the camera and deck and crash recording? or will there be menu options to set up?”
    It could not be much simpler.
    If you’re going from the camcorder to the deck:
    put the camcorder in VCR mode,
    set the deck for “DV Input”.
    You may (or may not) have a deck menu setting for choosing “External” timecode (if you care, look for it).
    Hit record on the deck, play the camcorder.
  • Paul Nevison
    August 16, 2005 at 1:16 pm
    cool thanks
    G5 DP 2.0
    2.0G RAM
    OS 10.3.8
    QT 6.5.2
    FCP HD 4.5
    CineWave 4.7
    Cinewave RT Pro
