Activity Forums Media 100 OT CNN Lower Third title bar
  • OT CNN Lower Third title bar
    Posted by Greg Ball on June 21, 2006 at 7:45 pm
    Does anyone have a useable photoshop file of a lower third background that CNN uses that you would be willing to share with me? I’m in need of using this on a project I’m just finishing up. I’m just not Photoshop savvy. I believe it spreads across lower third of the screen
    with a blue gray top and a white/gray bottom. The top is larger for the name, and the bottom is thinner for the person’s title or location. Thanks.
    Joe Hayden replied 20 years, 3 months ago 2 Members · 3 Replies
  • Joe Hayden
    June 21, 2006 at 10:12 pm
    Have you considered taping CNN and digitizing a clip so you could import a freeze frame into photoshop and try to copy the elements you like?
  • Greg Ball
    June 22, 2006 at 3:48 am
    Might be “slightly” easier if someone had a pre-built one for me.
    Thanks so much for your help…
  • Joe Hayden
    June 22, 2006 at 6:03 pm
    Not pre built but, try making a blue rectangle 786 x 60 (R14G86B157)
    70% opacity.
    Then a white rectangle 786 x 30 (R235G235B235) 100% opacity.
    Put the blue one over the white one with the bottom of the white settling a little below title safe.
    Good luck.
