Activity › Forums › Apple Final Cut Pro › OT: Beta update for X-Title Extractor for Final Cut Pro X
  • OT: Beta update for X-Title Extractor for Final Cut Pro X
    Posted by Andreas Kiel on February 14, 2015 at 10:39 am
    I’ve created a new version of X-Title Extractor – it’s beta.
    The older versions were all based upon the release of FCPX 10.0.1 which had a poor XML support. Later versions added the XML features of 10.1.x. So the app became quite a moloch.
    So I rewrote finally more or less the complete app. It doesn’t do the complicated analyze of Motion Titles any more. That makes it faster and also independent of the installed templates.
    Main thing though is that the complete timing stuff is rewritten from ground up, All apps which do a kind of same job as X-Title Extractor do have trouble to get the correct timing of titles out of a project XML. That’s why X-Title Extractor required an XML with subtitles only in the past to keep correct timing. With the new version this is not needed anymore – you will get the correct timing for each subtitle right out of a project. Subtitles in compound clips will be ignored. Transitions for subtitles will be handled the FCPX way. This means the subtitle timing will use the FCPX subtitle times for fade in/out or cross fade.
    As said, it’s beta.
    So several of the interface things are not connected, not working or simply not there. The help is not updated yet. The main things (standard import/export) are working.
    For me it would be very important to test subtitle timings and get some feedback. From the tests we had run it’s world’s finest app for this purpose – just a joke 🙂
    Final features will include:
    Project selection out of an event XML.
    Extended WebVTT support.
    Probably “color to speaker” option. If you don’t know what that means drop me an email.
    SBV support.
    Maybe optional DCP (Interop, SMPTE) support, this depends on feedback.
    Options to check for broadcast subtitles (character count per line, words per minute, characters per second, subtitle length etc).
    Support for Digital Heaven DH_SubtitleX.
    To download this beta go to:
    https://dl.dropboxusercontent.com/u/63959366/X-Title%20Extractor.app.zip
    Feedback is appreciated.
    – Andreas
    Spherico
    https://www.spherico.com/filmtools
    “He who fights with monsters should be careful lest he thereby
    become a monster. And if thou gaze long into an abyss, the abyss will
    also gaze into thee.” – Friedrich Nietzsche, Beyond Good and Evil
    Andreas Kiel replied 11 years, 3 months ago 2 Members · 2 Replies
  • W thomas Leroux
    June 8, 2015 at 5:47 am
    Andreas, this app is very handy! I needed to export all titles in a short timeline so the text could be sent off for translation, and your app did the trick. Brilliant work!
    https://www.leroux.ca/
    https://www.twitter.com/wtl
  • Andreas Kiel
    June 10, 2015 at 4:49 am
    Hi Thomas,
    Good to hear that is works fine for you.
    There is a release version now.
    http//www.spherico.com/filmtools/TitleExchange/XTE/XTE.dmg
    – Andreas
    Spherico
