Activity › Forums › Apple Final Cut Pro Legacy › OT – Additional RAM slowing me down?
  • OT – Additional RAM slowing me down?
    Posted by Max Frank on July 6, 2010 at 7:12 am
    I’ve got an old G5 that my assistant is using. Specs:
    2Ghz Power PC
    4.5GB DDR SDRAM
    OS X 10.5.5
    FCP 6.0.5
    A while ago, I added 1GB extra RAM that would bring it up to the 4.5GB mentioned above, but, to my mind, it seems to be running
    a LOT slower than before.
    Could the additional RAM possibly have caused a slow-down? Would it help to remove 500MB to bring it down to 4GB?
    Thanks in advance,
    Wayne
    Max Frank replied 16 years, 2 months ago 6 Members · 10 Replies
  • 10 Replies
  • Alex Elkins
    July 6, 2010 at 8:46 am
    Hi Wayne,
    For best performance all RAM modules should be the same size, and preferably the sane brand too. In addition to the new 1GB and the 500MB, what else is installed?
    All the best,
    Alex
    Salad Daze Films – Freshly Tossed
    Check out my latest addition to the Creative Cow Reels Section
  • Max Frank
    July 6, 2010 at 12:27 pm
    Hi Alex,
    Thanks for the prompt reply.
    Here is a screenshot of the RAM I have inserted.
    Does this help? Should I pull out the 500MB?
    Wayne
  • Max Frank
    July 6, 2010 at 12:31 pm
    Oops – wrong image!
    Here it is:
    Wayne
  • Walter Biscardi
    July 6, 2010 at 12:58 pm
    They’re all mismatched so that could be a problem. Typically I put in all the exact same RAM from the same manufacturer at the same time. I usually order a Mac with the bare minimum of RAM and then replace it all when it gets here with all new RAM from one source.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” featuring Sigourney Weaver coming soon.
    Blog Twitter Facebook
  • Max Frank
    July 6, 2010 at 1:31 pm
    Thanks Walter,
    Any suggestions which, if any, I should remove first?
    Wayne
  • Walter Biscardi
    July 6, 2010 at 1:34 pm
    I’d start with the 256’s and see if that helps.
  • Chris Tompkins
    July 6, 2010 at 7:24 pm
    I find Newer OS’s like 10.5.x installed on older slower machines to slow things down too…. FWIW
    Chris Tompkins
    Video Atlanta
  • Matt Campbell
    July 6, 2010 at 7:26 pm
    I too have had this issue with my old machine. MACs tend to be picky when it comes to installing new RAM. I had 6 gigs and went to 9, once installed everything was sluggish. After contacting tech support, they instructed me to install it in a certain way. I don’t remember what that was but he had me organize them in some weird manner. Whatever that was, it worked. Order and the chip size have a lot to do with it.
    OS 10.6.3, Mac Pro 2 x 2.66 ghz quad-core intel xenon, 16 gb ram, with BM Intensity Pro card
  • Terry Mikkelsen
    July 6, 2010 at 8:05 pm
    I too have misc. RAM modules (BUT ALL PAIRED) on a G5 2chip @ 2GHz. It is running 4GB of RAM and runs well (considering its age). So it isn’t necessary to have ALL the same sized chips. You could run the hardware examiner software to see if you have a faulty RAM chip. (That software may only come on the AppleCare disc, but there are other programs out there that will also work if you didn’t get AppleCare.)
    Having said all of that – I just noticed the differing numbers in your chip speeds. They are all 3200 which is good, but I was confused with the “-25440”. Did a google search for it – very interesting result.
    https://macosx.com/forums/archive/t-52201.html
    So, having read that – I would pull the 512 chips in slots 4&5 and see what that gets ya.
    Tech-T Productions
    http://www.technical-t.com
  • Max Frank
    July 12, 2010 at 12:11 pm
    Hi Gang,
    Thanks for the replies.
    A bit of an update.
    I’ve pulled out the two 256MB sticks. I’ve done a bit of work on the machine and I don’t know if it’s my imagination, but it does to be working a bit smoother, if not a teensy bit faster.
    I think the OS & software is probably too wieldy for that old machine to handle HDV efficiently, so I’m happy to have bare-bones operation whilst we do a few short things on that machine.
    Thanks again for the input.
    wayne
