Activity › Forums › Apple Final Cut Pro Legacy › OT: 3.2Gbps Firewire
Posted by Chris Borjis on December 17, 2007 at 8:22 pmLovely,
https://www.news.com/FireWire-speeds-set-to-quadruple/2100-1013_3-6223102.html?tag=nefd.top
I wonder if that means aja could update the io hd to do uncompressed.
Pxlmvr replied 18 years, 8 months ago 7 Members · 8 Replies -
Mark Maness
December 17, 2007 at 9:28 pmMaybe on the IoHD 2.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
https://blogs.creativecow.net/waynecarey -
Aaron Neitz
December 18, 2007 at 12:19 amI imagine while the ports stay the same, you’ll need upgraded busses and higher quality cabling than exists now.
It would be nice to have a fast consumer transport so we can forgo expensive fibre channel interfaces for uncompressed HD. You’ll still need some pretty speedy and robust drive arrays though.
Chris Borjis
December 18, 2007 at 12:32 am[Aaron Neitz] “It would be nice to have a fast consumer transport so we can forgo expensive fibre channel interfaces for uncompressed HD.”
I can’t wait! 🙂
Arnie Schlissel
December 18, 2007 at 1:07 amThis could be exceedingly cool! If we’re all lucky, we’ll only need a firmware upgrade. Even if we need to install a FW3200 card, it could still be very good for us. The odds are that FW3200 would be cheaper than eSATA or SAS.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Sean Oneil
December 18, 2007 at 1:18 am[Arnie Schlissel] “FW3200 would be cheaper than eSATA”
??? FW800 isn’t even cheaper than eSATA.
Sam Zimman
December 18, 2007 at 5:06 pmit would have a larger install basis if Apple started putting it on all their new computers. that’s the main reason I have FW800, because I can move my drive to many different computers without have to take a PCIX and/or PCIe card with me.
I doubt it will be a firmware upgrade. I think it is going to be live USB1 vs USB2. everything looks the same, but it’s more robust on the inside.
Pxlmvr
December 19, 2007 at 3:56 pmConcerning the question of need for newer cables and connectors, the article says:
“There is a very clear migration path from 800Mbps to 3.2Gbps, with no need for modifications to the standard and no requirement for new cables or connectors.”
A *very* nice feature.
