Activity Forums Adobe Premiere Pro OSX playback issues despite pref fix
  • OSX playback issues despite pref fix
    Posted by Marcus Smith on July 23, 2011 at 2:54 am
    Hey guys,
    Any Mac users out there experiencing smooth playback with Blackmagic hardware?
    Despite this fix:
    https://kb2.adobe.com/cps/842/cpsid_84287.html
    … sequences will play but every second time or so they will stop after 1 or two seconds. Other than that the systems seems reliable.
    Premiere reports dropped frames but blackmagic disk tests show that i am getting 320MBs read and write.
    I am working in pro res.
    System Specs:
    16 core Mac with 24GIG ram
    METASAN
    BLACKMAGIC HD EXTREME 3d with latest drivers.
    THanks,
    Marcus.
    Marcus Smith replied 15 years, 1 month ago 1 Member · 1 Reply
  • Marcus Smith
    July 25, 2011 at 12:30 pm
    Found the solution:
    Basically you have to use the bundled blackmagic presets of uncompressed 4:2:2 or AVC as your sequence preset. You can’t use any other codec like PRORES or premiere will stop playback and report dropped frames. A limitation certainly but still I’m stoked I can get the software to play in realitime… 😉
    Has anyone onlined a 10 bit 4:4:4 feature with premiere with a dual SDI on a mac? I have my doubts…
    Marcus
