Activity › Forums › DaVinci Resolve › Osx lion & cuda
Osx lion & cuda
Posted by Jacob Lanum on January 5, 2012 at 10:25 pmHello
I have just installed my first nvidia cuda card. Im getting 4fps on play back with 1 node. How do I know if cuda drivers are installed correctllyIm on 10.7.2 lion
Joseph Murray replied 14 years, 8 months ago 7 Members · 12 Replies -
Robert Houllahan
January 5, 2012 at 11:34 pmWhat machine is it in and what slot? Do you have a GT-120 as your GUI card? Resolve installs the CUDA drivers it needs to run.
-Rob-
Robert Houllahan
Director / Colorist
Cinelab Inc.
http://www.cinelab.comMAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma.
Jacob Lanum
January 6, 2012 at 12:13 amIm on a 2010 2.8quad, using the ati 5770 for gui. Right now the cuda card is in slot one looks like it should be in slot 2.
Joseph Owens
January 6, 2012 at 12:18 amYikes, kind of looks like you’re using the cards flopped and getting the commensurate performance.
jPo
You mean “Old Ben”? Ben Kenobi?
Jacob Lanum
January 6, 2012 at 12:38 amYeah next time i will read the manuel before buggin you guys.
Jacob Lanum
January 6, 2012 at 6:31 amwell I flopped the cards to be in the right slots. performance has increased to 11fps with 1node with an s curve, disappointing to say the least. I was getting much better results with my 5770. Is this how well a gtx460 should perform?
Margus Voll
January 6, 2012 at 7:01 amis 460 for mac ?
if not then you will probably not get any speed pump.
Margus
Sascha Haber
January 6, 2012 at 9:51 amAnd if it is, did you delete the Apple.PowerSavejadada.kext thing ?
Get this first :
https://sourceforge.net/projects/cuda-z/files/cuda-z/Beta/CUDA-Z-0.6.133-SVN.dmg/download
This will show you the CUDA supported engines found in your ystem and test them for you.
If you dont see a drop down menu in the very beginning, your 460 is not for Mac of something else is wrong.
If you see it and the performance is doooh, you need to delete that Powersace kext and reboot.A slice of color…
DaVinci 8.2.1 OSX 10.7.2
MacPro 5.1 2×2,4 24GB
RAID0 8TB
GTX 470 / Quadro 4000
Extreme 3D+ICA Instructor
https://www.icolorist.com/Sascha.html -
Dan Moran
January 6, 2012 at 2:38 pmHey Jacob,
If you send me a mail at davincihelp@blackmagic-design.com I’ll sort you out.
Dan
Dan Moran
DaVinci Application Specialist
Blackmagic Design EMEA -
Jacob Lanum
January 6, 2012 at 6:00 pmthanks for the tip Sascha! This baby is flying now! card still seems to be a little glitchy flashing black boxes on resolve vid screen. I’m getting close thanks for all the help
Joseph Owens
January 7, 2012 at 7:37 pm[Sascha Haber] “t and the performance is doooh”
Do we have any benchmarks for what is “doohhh”?
I have a pair of GT480s running in a 16xCubix, and the Single Precision Float processing per GPU is around 1331 GFlop/sec. Double Precision around 168 GFlop/sec. The Host/Drive rate is about 5748 MiB/s.
What kind of numbers do you see?
I am away from my Q4000 system this weekend, but I’d be curious to run this gauge on it.
jPo
