Activity Forums Sony Cameras OSStatus error -12909
  • OSStatus error -12909
    Posted by Susana Travieso on May 27, 2010 at 3:31 pm
    Quick question:
    When I import the clips from an EX1r to a Mac Book Pro and try to open the MP4 clips I get the message:
    “The operation couldn’t be completed. (OSStatus error -12909.)”
    Do I need a plug in so that QTime Player can play the clips? I just want to watch them before I store them in a drive, no editing required.
    Susana Travieso replied 16 years, 3 months ago 3 Members · 7 Replies
  • 7 Replies
  • Clint Fleckenstein
    May 27, 2010 at 3:53 pm
    You are supposed to be using the free Sony Clip Browser. If you’re just extracting the MP4 clips off your card, you are SERIOUSLY breaking your footage.
    You must not have Final Cut Studio installed on your MacBook, which means that you can not view the files in Quicktime. You can purchase an MP4 codec from Calibrated Software to do that.
    Again, since you’re talking about the MP4s, and have not mentioned either of the free Sony software products, I’m led to believe that you are very dangerously mishandling your footage. You need to stop and learn the workflow properly before you are bitten by this. Read this forum thoroughly, this sort of thing is explained ad nauseam if you scroll down the posts.
    Just out of curiosity, just how ARE you “importing the clips?”
    Cf
  • Craig Seeman
    May 27, 2010 at 4:06 pm
    Camera operator hands Assistant BetaSP tape. Assistant promptly breaks open the cassette and puts the crinkled tape into deck and then wonders what’s wrong.
    I apologize. I can’t help myself.
    Don’t separate contents from BPAV as it’s the cassette.
    BPAV in ClipBrowser with CRC to Hard Drive.
    BPAV on Hard Drive to XDCAM Transfer for MOV wrapping for Final Cut Pro.
    ClipBrowser can play the clips.
    FCP 6.0.2 and up required to have codec for Quicktime Apps to play.
    Alternately one must buy Calibrated Software plugin for non FCP systems for Quicktime playback.
  • Susana Travieso
    May 27, 2010 at 4:10 pm
    Thanks for your reply–
    I am using the SDHC cards with the adapter. I am downloading the clips to the laptop with the reader.
    I am using the Sony Clip Browser just to see that the data is all there but I can’t really see the quality of the footage. Thought I could open the clip to QTime reader and see it there.
  • Susana Travieso
    May 27, 2010 at 4:23 pm
    Thanks for your reply and no need for sarcasm. I know that BPAV stays together and that’s how I handle it. My question is if I don’t have FCP how can I check the footage since Clip Browser does not really have a good window to watch the clips.
    So far I’ve worked in 3 shoots and have not have any problems with the workflow, but the clients always ask how they can check the quality of the footage.
    Thanks for your help.
  • Craig Seeman
    May 27, 2010 at 4:36 pm
    Windows
    https://www.calibratedsoftware.com/MP4EXImport_Win.asp
    Mac
    https://www.calibratedsoftware.com/MP4EXImport_Mac.asp
    The computer still needs to have the horsepower to play them back properly. Keep in mind that a computer monitor is not likely to be color calibrated for broadcast playback.
    May 27, 2010 at 5:58 pm
    You also want to use the Clip Browser to do your copying, because you have the ability to turn on CRC error checking in the application’s preferences. That can help safeguard against corrupted clips.
    I have the Calibrated Software codec on one of our machines, it’s great and the price is reasonable.
    Cf
  • Susana Travieso
    May 27, 2010 at 7:21 pm
    Thank you, much appreciated!
