Activity › Forums › Adobe After Effects › OS X Tiger and no keyboard shortcuts
Posted by Alisdair Jones on May 2, 2005 at 4:14 pmUpgraded to OS X Tiger 10.4 with a clean install. Installed After Effects Pro 6.5.1 and upon launching AE, I get this message:
After Effects: KCHR resource not found, keyboard shortcuts will be disabled.
As it says, none of the keyboard shortcuts work.
This is on a 15″ Powerbook 1.5Ghz. Did I miss an option on my Tiger install?
-cheers, Alisdair Jones
Sami Syrjä replied 21 years, 1 month ago 6 Members · 7 Replies -
Hipshaker
May 3, 2005 at 10:38 amFinally! Someone else with the same error. I’m on an Imac g5 20″ myself. Guess it’s just a matter of time now, before we will see more and more people pop up with the same problem, once more and more uprgade to Tiger.
Aaron Schurman
May 6, 2005 at 6:33 pmI have AE 6.5 installed on a 15″ Powerbook with 1.5Ghz G4 and running tiger and so far no problems. Maybe see if you can downgrade to AE 6.5 instead of 6.5.1. Just a thought.
::AARON SCHURMAN::BOYWONDERSTUDIOS::
::WEB::https://www.boywonderdesign.com::::MOTION GRAPHICS :: VIDEO :: PRINT
:: AD :: WEB :: IDEASAREDANGEROUS -
Alisdair Jones
May 6, 2005 at 6:40 pmI might just give that a try.
Thanks for your response Aaron.
cheers, Alisdair
Alisdair Jones
May 9, 2005 at 10:27 pmI’ve found a solution to this bug. I had my keyboard input prefs set to Canadian and upon changing them to US the problem goes away.
cheers, Alisdair
Tobias Lind
May 16, 2005 at 1:50 pmThat’s no solution for Swedish keyboards using International english system…
Ross Goldstein
July 6, 2005 at 5:40 amhow do you change your keyboard input prefs? I’m having this problem too and desperately want to use shortcuts again soon.
Powerbook G4
Mac OS X 10.4.1
Memory 1GB DDR SDRAM
CPU Speed: 1.5 GHz -
Sami Syrjä
August 11, 2005 at 6:32 amSo nobody has found a solution this yet? Switching to US English every time to have shortcuts in AE will be frustrating. We just updated to Tiger and now I’m having the same problem on our new G5 PowerMac.
Ross, in case you haven’t found out yet, you can change the input prefs in system preferences/international
-sami
