Activity Forums Apple OS X OS X Lion – read/write permission problem GTech external drives
  • OS X Lion – read/write permission problem GTech external drives
    Posted by Sean Eunson on April 18, 2013 at 4:48 pm
    Just thought I would post this as an FYI. I recently got an iMac i7 with 32Gigs of Ram. It has 10.8.3 as the operating system. Here was my problem which in the end was easily solved. I have 4 external GTech Raid drives – all different sizes from 1TB to 4TB. When I tried to write a file to them – only one drive would allow it. The 4TB. The other drives said I could not plop a file on them. They appear on the desktop fine – the file existing on them are fine. But I could not write a simple Open Office text file to them. Looking in the Get Info on each of the drives they all had read/write and were identical to the 4TB (Mac OS extended by the way) Everything was identical except size and writing permissions.
    I opened up “About this Mac” “More Info” “Report” and went to storage. Writable was “No” on all the drives I had a problem with. I went to “Disk Utility” and ran the “Verify” on each drive and it tells me the drives are ok. But guess what – this solved the problem. I was able to write to the drives. I then looked at the About this Mac info – it still said “No” on writing. I solved that by rebooting the machine and Voila! it says “Yes” on write.
    Hope this helps you all. Thanks.
    Michael Wright replied 13 years, 2 months ago 7 Members · 17 Replies
  • 17 Replies
  • Jeff Greenberg
    April 20, 2013 at 3:09 am
    That’s very odd.
    Did you try changing the drives to ignore permissions?
    Best,
    Jeff I. Greenberg
    Author/Master Instructor/Speaker/Consulting
    My contact info and more
    New! Come see me speak @ NAB/Post Production World!
  • Sean Eunson
    April 20, 2013 at 1:36 pm
    One thing I forgot to mention. The drives were coming off the thunderbolt port via a thunderbolt to FireWire 800 converter. The drives were all chained together. The 4TB was not first or last.
  • Sean Eunson
    April 29, 2013 at 3:28 pm
    The Saga Continues…. Each morning as i come in to start my day the drives in question continue to exhibit this behavior. I have to go to Drive Utility and run “Verify” to re-set the write to yes. Anyone else having this problem and Im assuming its Mountian Lion and not Gtech but im now not entirely sure?
  • Jeff Greenberg
    April 29, 2013 at 4:05 pm
    The easiest way you can check everything is to bring your drives to another mac.
    Did you check the Main Drive permission (as I suggested) on OSX – to bypass it entirely?
    I have here (connect via Tbolt & USB 2/3) some 1/2 dozen drives – none of which exhibit this behavior.
    You might consider installing mountain lion on a different HD and see if it still has this issue.
    Best,
    Jeff I. Greenberg
  • Sean Eunson
    April 29, 2013 at 4:34 pm
    Thank you for responding. Sorry I did not get to your suggestion before. I actually did bring the drive in question from my machine to another machine (Same new iMac – Same OS – Same thunderbolt to 800 adaptor) when I mounted the drive on this machine it had corrected the write to “Yes” and when I brought it back to my machine it continued to say “Yes” so Ill see what happens when I shut down which I do every night (note – it does not set the permission when I re-start only when I shutdown and re-boot)
    As for your suggestion – im unclear on how you bypass the permissions on the main drive? And you are talking about the “Macintosh HD” when you say this?
  • Jeff Greenberg
    April 29, 2013 at 4:36 pm
    Click on the drive itself.
    Choose Get info.
    Unlock the drive.
    Choose “Ignore Permissions on this Volume”
    If the drives aren’t having a problem on a different mac, it’s likely a problem with your system itself.
  • Sean Eunson
    April 29, 2013 at 5:21 pm
    Got it. I see that and I think – but not certain – that it was already selected. Ill post further in future.
    Here is an oddity though. I have 4 external drives connected – all GTech raided drives and one of the drives does not have that option? But its not the drive that changed the write capability?
  • Jeff Greenberg
    April 29, 2013 at 5:30 pm
    That option has to do with the format of the drives.
    It’s present in HFS+; not there in NTFS, FAT32, exFat.
    Are all the drives HFS+?
    Best,
    Jeff I. Greenberg
  • Jyoti Roy
    May 1, 2013 at 9:49 am
    You have to check the permission of external drive with the help of Disk Utility.
    Disk Utility has ‘verify’ option which helps you to check read/write operation.
  • Sean Eunson
    May 1, 2013 at 3:52 pm
    2 of the drives (of 4) are Journaled HFS + and 2 are just HFS+.
    Yes checking the “verify” in Drive Utility solves the problem but it keeps coming back. But today all drives still have write permission as “yes” so I guess its a minor inconvenience if it comes back. Thanks all
