Activity › Forums › VEGAS Pro › Orphaned & Unreachable?
  • Orphaned & Unreachable?
    Posted by Christopher Rotter on December 16, 2006 at 11:40 pm
    Hello, I was about to compile a DVD when I went about doing so I get a error. Playlist 1 orphaned and unreachable, so I looked in the manuals for clues on my problem and no such luck, any idea?
    Christopher Rotter replied 19 years, 9 months ago 2 Members · 4 Replies
  • George Wing
    December 17, 2006 at 1:04 am
    I think it means your project has an item called “PLAYLIST 1” (look in the tree structure on the left), and there are no buttons or “end actions” pointing to “PLAYLIST 1” (so DVDA thinks it is just “hanging” there without any means to play it back).
    Regards,
    George
  • Christopher Rotter
    December 17, 2006 at 1:56 pm
    So I have to add a button or a action ? I do have an item called “playlist 1” though.
  • George Wing
    December 17, 2006 at 4:27 pm
    [CSheep] “So I have to add a button or a action ? I do have an item called “playlist 1″ though.”
    It’s up to you. You can ignore the warning, and build the DVD anyway. Or if you really don’t need the Playlist, then you can remove it from your project. Or if you want to be able to view the playlist during dvd playback, then add a menu button (or an end-action from another asset) to link to the playlist.
    Regards,
    George
    December 17, 2006 at 9:20 pm
    What is a playlist and what are the pros & cons of one ?
