Activity › Forums › Sony Cameras › orphan files plus heads-up on Seagate drives
  • orphan files plus heads-up on Seagate drives
    Posted by Stephen May on January 30, 2009 at 8:22 pm
    Hi all – I haven’t been very active here in a long while, but I need to post two things. First, even after all this time, I still sometimes have issues with orphan SxS files – where the recorded clip extends from one card in slotA over to the second card in slotB.
    I’ve never used the technique where many of you have mentioned copying the entire BPAV folder until this morning just befor shooting on the hill. I used my Macbook Pro at home to ingest two cards; a 16GB Sony that was full including a long doc that extended over to another Sony 8GB SxS card. I named the clip on the 16GB card and assumed it would grab the other half and join it together after I mounted the 8GB card, but it didn’t. The clip ended early. Knowing I needed these cards, I didn’t have time to copy the BPAV folder from the 16GB card, but I copied the 8GB card, which is the part of the clip that didn’t come in. If I’ve explained this properly, what would you guys recommend in order to get the second half of the clip off of this card?
    On another subject, be aware that Seagate has a relatively serious firmware update that many of their larger drives require. I happen to own sixteen of them! They’re the Barracuda 1 terabyte 7200.11 drives. You can go to the Seagate support site to find out if your drive falls into this group. Our DAT Optics external RAID is still running like a Leopard on crack (couldn’t think of anything else…) but the Seagate firmware update is a bit of a bummer. That’s why we backup and backup and backup…
    Cheers – btw, if you guys have covered the SxS orphan topic a bunch of times, please just direct me to those posts. Thank very much! -s
    Craig Seeman replied 17 years, 7 months ago 3 Members · 2 Replies
  • Marvin Holdman
    January 30, 2009 at 9:38 pm
    Hi Stephen,
    If I understand correctly, you are describing a “spanned clip” in which a single clip goes from one card to another. The way we’ve always approached this is first, but downloading the BPAV folders into a series of folders (disk01, disk02, disk03 and so forth) and then at the end of the day, combining them into a single BPAV folder using the EX-1 clip browser software.
    When you do this, it automatically recombines spanned files.
    Hope this helps.
    Marvin Holdman
    Production Manager
    Tourist Network
    8317 Front Beach Rd, Suite 23
    Panama City Beach, Fl
    phone 850-234-2773 ext. 128
    cell 850-585-9667
    skype username – vidmarv
  • Craig Seeman
    January 30, 2009 at 10:28 pm
    I’m not quite sure what you’re doing but simply
    ClipBrowser
    Copy BPAV to folder on hard drive
    Copy BPAV on next card to folder on hard drive
    XDCAM Transfer
    Add parent folder containing BPAV
    Add 2nd parent folder containing 2nd BPAV
    Select All
    Import All
    That’s it. Anything else and you’re making something that should very easy into something unnecessarily difficult
