Original media from HDV to FCPX to Adobe Premier?
For a student project that was shot in HDV, I used FCPX in capture the data. It works great in FCPX, but the student wants to edit in Adobe Premiere, which does not recognize the the file, called original media in FCPX library. It opens in Quicktime on my Mac and the inspector calls it a quicktime movie, Format HDV 1080i60, 1440 x 1080, Linear PCM, 32 bit little-endian floating point, 48000 Hz, Stereo. FPS 29.97. It seems to be a codec issue (his PC and Premiere). Is there a way to rewrap it or something that leaves the media the same, but will allow him to open it?
I sent it through FCPX and compressor and then he could open it, but that is not the original data from the camera.
The other solution is from him to capture again from the tape, but he doesn’t have firewire, which is needed for the old fashioned capture from tape.
Thanks, Claude Lyneis
