Activity Forums Adobe After Effects orient a 3d layer between multiple 3d nulls
  • orient a 3d layer between multiple 3d nulls
    Posted by Jason Mckee on July 23, 2014 at 3:44 am
    is it possible to orient a 3d layer between multiple 3d nulls. it seems like there should be a way to orient a 3D layer between 3 nulls.
    Walter Soyka replied 12 years, 1 month ago 2 Members · 1 Reply
  • Walter Soyka
    July 23, 2014 at 2:29 pm
    [Jason McKee] “is it possible to orient a 3d layer between multiple 3d nulls. it seems like there should be a way to orient a 3D layer between 3 nulls.”
    Looks like a good feature request for keen_3dLayerTools [link] [link]!
    In the meantime, try these expressions.
    Position:
    // applied to the position parameter, this expression computes the triangular centroid of a plane defined by three points
    p1 = thisComp.layer("Null 1").transform.position;
    p2 = thisComp.layer("Null 2").transform.position;
    p3 = thisComp.layer("Null 3").transform.position;
    // the centroid is the average of these points
    centroid = div(p1+p2+p3,3);
    Orientation:
    // applied to the orientation parameter, this expression looks down the normal of the a plane defined by three points from its centroid
    // the normal vector of a plane is (p2-p1) x (p3-p1)
    n = normalize(cross(p2-p1,p3-p1));
    // use lookAt to get the orientation necessary to look along the normal vector from the centroid
    lookAt(centroid,centroid+n)
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
