Activity Forums Boris FX Organizing too many Spline Tracks from imported EPS doc
  • Organizing too many Spline Tracks from imported EPS doc
    Posted by Maxwell Federman on August 20, 2013 at 3:09 am
    Hello–
    Just imported an eps file into RED 5, set the track shape to 3D line art and then selected convert to container.
    As expected, I can now see all the layers as spline tracks.
    And it appears that instead of preserving the layers from Illustrator, RED has this time around gone a step further and created a spline track for each individual element within a given layer. More specifically, two of the layers in Illustrator are words, and now there’s a spline track for each letter.
    For me personally, the RED UI is a more familiar place to be than Illustrator. So here’s my question– can I make nested containers? I tried to create a second 3D container inside the one created after changing the track shape, selected a words worth of spline tracks (all of the letters of a word) then cut and pasted these tracks into a second container. The issue is that now the stuff pasted in the second container is nowhere to be found. What might I be overlooking here? I really don’t want to have to go back into Illustrator– not a big fan of adobe products
    Max
    Maxwell Federman
    Owner
    Capitol City Media
    Austin, TX USA
    http://www.capitolcitymedia.com
    Peter Mcauley replied 13 years ago 2 Members · 1 Reply
  • Peter Mcauley
    August 23, 2013 at 3:12 pm
    Hi Max,
    The only thing that can exist in the Path track of a Spline Track is a Spline Object so you can’t add Containers to nest the splines. There are two options available (that I know of) to properly nest the shapes:
    Automatic:
    • select the
    • duplicate the master spline path track that contains all of the spline object sub-tracks from your EPS file – make a copy of the track for each of the groups that you want to create (for instance, if the imported EPS was of the letters ABC, then you should have 3 identical copies of the spline track
    • twirl open the spline tracks to reveal the spline objects that are nested under the path track
    • delete the spline object sub-tracks from each spline track so that each master spline track has only the spline objects for each letter and no duplicates
    • you can then nest all of the spline tracks into a 3d container
    I hope this helps.
    Peter.
