Activity Forums Adobe Premiere Pro Organizing Assets when doing all CC within Premiere
  • Organizing Assets when doing all CC within Premiere
    Posted by Jim Bachalo on May 11, 2012 at 10:41 pm
    Hi
    Need some advice on feedback for the best way to organize your assets and workflow.
    Right now I have bins for Sync(clips requiring audio sync), MOS(clips without sound), Images, Audio, and FInal Edits(for all my edit sequences)
    I was wondering if it is best to stick with a linear workflow,
    ie
    1-do all your editing
    2-do any primary color correction
    3-do any secondary correction
    4-further secondary correction involving masking
    5- final grading
    OR
    would it make more sense to adopt some sort of parallel workflow?
    ie while you do your editing you could also be identifying clips that require stabilization, noise reduction, secondary CC and working on those identical clips but in other sequences named after the respective function
    ie 1 sequence named ‘Secondary CC’ containing ALL clips requiring secondary CC, etc.
    Is this type of workflow possible? I was thinking that it might be if you used nested clips but will have to try first.
    Local is the new global
    Jim Bachalo replied 14 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
