Activity Forums Adobe After Effects Organic text movement
  • Organic text movement
    Posted by Fabiano Peres on July 21, 2006 at 12:22 pm
    I need to makea text move like a snake. I know that I could use a line as a path to animate my text, but I need it to be in 3D space, as if we were seen a snake from above.
    Can anyone tell me how to do that wit After Effects?
    Is there any plugin to arganicly animate objects?
    Thanks for the attention.
    David Bogie replied 20 years, 2 months ago 3 Members · 2 Replies
  • Mylenium
    July 21, 2006 at 3:43 pm
    Mmh, I don’t quite follow. What would be wrong with pre-composing the animated text and using that composition as a 3D-layer? If you use the collapse transformations switch, you even get the best possible quality. Other than that, look at Dan Ebbert’s site (www.motionscript.com), he has a wonderful explanation on creating any kind of trailing effects.
    Mylenium
    [Pour Myl
  • David Bogie
    July 21, 2006 at 7:32 pm
    If you want to learn how to do stuff like this yourself, try
    https://theanvel.com/
    look for the NAB class downloads.
    Dean Velez takes a unique approach to organic movements.
    bogiesan
