Activity Forums Maxon Cinema 4D Organic lily shape
  • Organic lily shape
    Posted by Rosie Woods on September 12, 2018 at 12:05 pm
    Hi there,
    I’d really like to create float/twisty/ frilly shapes such as a Cala Lily’s in C4d but struggling to find any good tutorials online. So far I’ve been using planes and the jiggle deformer to get something similar but I’d like more control on the process. Can anyone advice on me on the best way to do this please.
    Many Thanks,
    Rosie
    Rosie Woods replied 8 years ago 2 Members · 4 Replies
  • Brian Jones
    September 14, 2018 at 2:35 am
    hard question because there are probably many ways. An inverted cone with no caps might be a good start, sliced and wrapped a bit more than 360 to get the overlap (I see in images), then soft selections and or the magnet tool or the sculpt system. But there is definitely more than one way
  • Rosie Woods
    September 18, 2018 at 1:39 am
    Hi Brian,
    Thank you so much for your response! I didn’t know the Soft selection and magnet tools even existed. Game changer for me thanks! I have a quick follow up question. After I’ve sliced and wrapped the cone (thanks didn’t know this was possible either) how do I separate the overlapping segments of the cone so it resembles that spiraled look. At the moment it still looks like a cone. I’ve tried a few different ways with the selection tools but I’m stuck. Sorry!
    Rosie
  • Brian Jones
    September 18, 2018 at 3:02 pm
    Do an Optimize (Points Mode) after you make the cone editable as there seem to be a couple extra points and then use the soft selection in Surface mode which will make sure the points that move are along the surface in the distance range and not just “every point in range”.
    After you get the shape close, moving single points (or sculpting if you have Studio). There has to be more than one way to do this and using as few points as possible inside a Subdivision Surface and extruding edges out from a source would be a choice too. I just did a quick test, took a disk object and reduced the segments to 12 and did the same over-wrapped slice, then extruded the outer edges upward all in an SSD to smooth. Totally not a good attempt (quick) but the initial shape is there without a lot of work.
  • Rosie Woods
    September 21, 2018 at 2:09 am
    Thank you, Brian. SO HELPFUL!
    I really appreciate that you took the time to do this for me ☺ I’ve learnt so much in a few simple sentences. I’m using C4d to create paintings. You’ll see some of these soft shapes popping up soon! My Instagram is @itsrosiewoods or https://www.itsrosiewoods.com
    Wishing you all the best ☺
    Rosie
