Activity Forums VEGAS Pro order of imported fotoz
  • order of imported fotoz
    Posted by Bob Tyson on October 13, 2010 at 7:06 pm
    Aloha Gang,
    importing “still image sequence” to time line and fotoz in sequence end up in reverced order on timeline. can’t seem to figure what I’m doing wrong.Thanks for your time…..V8.0c……..bobt
    Bob Tyson replied 15 years, 11 months ago 2 Members · 4 Replies
  • Mike Kujbida
    October 13, 2010 at 7:07 pm
    Are you clicking ONLY the first one in the sequence when you’re at that window?
  • Bob Tyson
    October 13, 2010 at 7:33 pm
    Aloha Mike,
    Imade a seperate folder for just the images to use in sequence and may have only selected the 1st image thinking that it showed the last image in that folder in the bottom dialog.I am not at machine right now so will check as soon as can. Iassume you mean select all or at least 1st and last of the group to be used? Thanks for your time and will check it out…..bobt
  • Mike Kujbida
    October 13, 2010 at 7:38 pm
    Bob, I mean click the very first one only.
    Click on image001.jpg ONLY and then go to the next step.
    Vegas will automatically load the rest of them.
  • Bob Tyson
    October 13, 2010 at 10:31 pm
    Aloha Mike..understand and will give it a worl when I get back to that machine. Thanks for your time….bobt
