Activity Forums Boris FX Order in which Boris plugins utilized.
  • Order in which Boris plugins utilized.
    Posted by Andrew Hillo on December 4, 2010 at 11:02 pm
    Hello folks, I have a 1920 x 1080, 2 hour long re- edit of a silent classic, I would like to Rezup, stabilize and retint the project, What order should I use them in?
    Boris Yamnitsky replied 15 years, 9 months ago 2 Members · 1 Reply
  • Boris Yamnitsky
    December 5, 2010 at 4:15 pm
    That’s a really good question. As a rule of thumb, you should always stabilize first because any pre-processing may confuse the Optical Flow algorithm. Make sure to select Magic Sharp from the Quality popup in the Post Processing group (it defaults to fast). You are going to need all this extra precision in the next step which will be UpRez. All color adjustments should be done last.
    Boris Yamnitsky
    BorisFX
