Activity Forums Apple Final Cut Pro Legacy Optomizing video for Youtube
  • Optomizing video for Youtube
    Posted by Mark Mckay on January 14, 2007 at 8:47 pm
    Can anyone tell me the best settings for outputting my video for Youtube? I have used Apple Compressor and Sorenson Squeeze using a variety of settings, including those recommended by Youtube, and always get the same results. The video looks good before I upload it, but once its up on Youtube it looks like crap. My files are too big to put up uncompressed as Youtube restricts the size to 100MB.
    I wonder if the problem might have something to do with my source video, I use a SONY DSC-M2 MP4 video camera. Could this be the problem? I use lots of clips from TV in my show that are captured using MINIDV and there quality is effected too, so it appears to me that the problem isn’t with the source, but with my compression settings.
    Here is a link to my most recent video so you can see what I am talking about:
    https://youtube.com/watch?v=j4Cgy8tzw48
    And here are the settings I used in Compressor:
    Description: H.264 for LANs/Intranets
    File Extension: mp4
    Estimated file size: 39.53 MB
    Audio Encoder
    Format: MPEG4
    Sample Rate: 44.100kHz
    Channels: 2
    Bits Per Sample: 16
    AAC encoder quality: high
    Video Encoder
    Format: MPEG4
    Width: 320
    Height: 240
    Pixel aspect ratio: default
    Crop: None
    Frame rate: 29.97
    Frame Controls: Off
    ISMA Profile: 0
    Constant bit rate: 2048 (Kbps)
    Mark Mckay replied 19 years, 8 months ago 3 Members · 3 Replies
  • Bouncing Account needs new email address
    January 15, 2007 at 1:40 pm
    The weak link is the YouTube RE-compression on their end,
    All you need to do to check this is to send a 5 second high-rez test clip and look at what happens to it,
    YouTube does offer a much higher level of clip storage if you sign up and pay for the service,
    That’s why some of the videos you see (mostly from networks and movie companies) look so much better.
  • Enzo Tedeschi
    January 15, 2007 at 9:20 pm
    Mark,
    Nice vid – I dig it 🙂
    It’s about the quality I would expect from youTube. The only thing you can do is create the highest quality file you can at your end – the cleaner the source, the cleaner your youTube recompression will be. I’ve uploaded a few different sources to my youTube channel: http://www.youtube.com/outpostpps and the results vary a little, but by and large you are dealing with some massive crunching at the youTube end when you upload.
    Keep up the good work.
    Enzo Tedeschi
    ____________________________
    Editor
    http://www.outpostpps.com
    Sydney, Australia
    YouTube Channel – http://www.youtube.com/outpostpps
    Check out the Outpost Video Podcast – http://www.outpostpps.com/podcast/
  • Mark Mckay
    January 23, 2007 at 3:42 pm
    Hey guys thanks for your help.
    I have discovered that part of the problem is with the video that I started with. It didn’t show up on my moniters, but when I checked at work, my source file doesn’t look so hot. I used Sony’s DSCM2 MP4 camera to make the show and the camera doesn’t give as good a picture as I thought.
    Mark
