Activity › Forums › Apple OS X › option key settings
  • option key settings
    Posted by John Barnard on April 16, 2008 at 2:06 am
    Hi there, I just started using a Final cut pro 6 system, after a long time using version 5.
    To my dismay the “OPTION-click” feature (where you hold the option key while dragging an in point) does NOT work as it did on my old computer.
    Everyone says it should work and it’s not final cut that’s causing the problem. Could it be my keyboard or language settings that would cause the OPTION function to be disabled?
    Blackmagic Multibridge
    Final Cut 6
    Mac Pro
    Model Identifier: MacPro1,1
    Processor Name: Dual-Core Intel Xeon
    Processor Speed: 3 GHz
    L2 Cache (per processor): 4 MB
    Memory: 3 GB
    Bus Speed: 1.33 GHz
    SONY HRV – D1800 HDCAM deck
    SOND HRV – 1500 HDV deck
    John Barnard replied 18 years, 5 months ago 2 Members · 2 Replies
  • Simon Carlson-thies
    April 16, 2008 at 7:13 pm
    Check in your system prefs under keyboard and mouse and look to see if your modifier keys have been changed.
    Simon Carlson-Thies,
    Complex Technology Development
  • John Barnard
    April 17, 2008 at 5:03 pm
    Believe it or not, one of my option keys is broken. The other side of the keyboard works fine!
    Final Cut 6
    Mac Pro
    Memory: 3 GB
    Bus Speed: 1.33 GHz
