Activity › Forums › Apple Final Cut Pro Legacy › Option + Dragging Transition Problem
  • Option + Dragging Transition Problem
    Posted by Kevin Monahan on May 4, 2008 at 6:08 pm
    Option + Dragging or Option + Selecting anything doesn’t seem to work the same way as it used to.
    Let’s say I have an audio and a video transition at the same edit point. I like the audio transition but want to shorten the video transition. When I grab the handle and attempt to shorten it, the audio transition moves in tandem.
    What is up with that?
    OK fine. It’s a linked selection item? I’ll option + drag it. The audio transition still moves. Lock it? it STILL moves!
    The only way I can do what I want to do is to turn off Linked Selection. I don’t like this because I don’t think an audio and video transitions duration should be related whatsoever.
    Command + selecting items seems to have changed as well. It doesn’t work the way it used to as it did even after auto-select was brought into the fray.
    Thoughts on this?
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
    Kevin Monahan replied 18 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
