Activity Forums Apple Final Cut Pro Legacy Option-Command-Click, moves windows
  • Option-Command-Click, moves windows
    Posted by Lu Nelson on October 13, 2009 at 7:38 pm
    Does anyone know a way to disable the behaviour — because I don’t know if it is coming from FCP or the System itself — where option-command-clicking in FCP results in the cursor “grabbing” the entire window and moving it, rather than allowing me to use it simply as a modified click?
    I ask because there was a post on Little Frog which linked to an old Ken Stone article about the various uses of the “option” key in FCP, and that article mentioned using command and option in combination, which in my system doesn’t work at all, it just moves the entire window rather than allowing me for example to select multiple non-linked edit points, or other variations which the Ken Stone article seems to suggest it should
    Very curious to see if anyone knows…
    Lu Nelson replied 16 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
