Activity › Forums › Adobe After Effects › Optimum Workflow for FCP > After Effects
Posted by Frederic Lumiere on June 8, 2010 at 2:33 pmAnyone has recommendations for the optimum workflow to go from FCP 7 to After Effects?
Frederic Lumiere
https://FredericLumiere.comFrederic Lumiere
Producer
Lumiere MediaFrederic Lumiere replied 15 years, 6 months ago 4 Members · 7 Replies -
Kenny Miracle
June 8, 2010 at 2:59 pmAutomatic Duck is a nice plugin that will translate all your effects, keyframes, cuts, fades, etc from FCP > AE.
https://www.automaticduck.com/products/
Other than that – I would recommend doing the edit first in FCP. Get your content & audio set in stone. Then take it into AE. If you start doing heavy graphics, then your music or content changes – you’ve wasted time. I’ve had that happen and it’s not fun 🙂
Peace,
KennyKenny
Steve Roberts
June 8, 2010 at 4:01 pmI agree. Get the timing down in the editing app, nail down all cuts. Then add the graphics by exporting the relevant section (if necessary) from FCP with current settings (no change). Do your magic in AE, then render to the codec of the FCP sequence, otherwise FCP will have to render in the sequence … the exception being if you have to use alpha channel, to render to the Animation codec with AE.
Now … if you’re editing in FCP with a codec such as HDV or MPEG-2 (an interframe-compressed codec) you must convert it to a proper intraframe-compressed codec (P-JPEG, PNG, Animation, 8-bit 422, ProRes) before importing into AE. Then you should render to the same proper intraframe codec, and use something like Quicktime to convert that movie to the HDV/MPEG-2 codec if you want.
I hope that makes sense …
Kenny Miracle
July 5, 2010 at 2:57 pmWhen to add transitions… it really depends on the project. simple fades, cuts, color dissolves can be done easily in FCP.
But if you’re wanting to do more fancy transitions, like lens flares or graphical wipes or something else that requires AE, then there are two common options:
1) Export your FCP timeline with cuts only & add transitions in AE when doing other fx work
2) If you’re not already sending your project to AE, then you can export your AE transition as an Animation with an alpha channel, and just drop it into FCP.I like exporting transitions out of AE, becuz then I can have them available for other projects.
Hope this helps,
KennyKenny
Jan Becker
July 5, 2010 at 7:22 pmHey Kenny thanks for the helpful tips.
I’m brand new to AE, so far I only worked with FCP and Motion.
Do you know of a Tutorial that focuses on the FCP – AE workflow?
I’m going through a Lynda.com tutorial, but they don’t really touch this topic.Thanx,
Jan
Kenny Miracle
July 5, 2010 at 8:42 pmIf you’ve used FCP & Motion together, then switching to AE shouldn’t be too complicated. I’ve never found a “best practices” for the FCP/AE workflow. Some good techniques have been discussed, but it really depends on your workflow & needs.
Kenny
Frederic Lumiere
February 24, 2011 at 1:02 pmThanks Kenny!
It all worked out beautifully thanks to your recommendation to using automatic Duck. Here’s a couple stories about my workflow:
Frederic Lumiere
Producer
Lumiere Media
