Activity › Forums › Adobe Premiere Pro › Optimum Setup for Premiere Projects
  • Optimum Setup for Premiere Projects
    Posted by Chris Holland on January 13, 2006 at 3:49 pm
    I have been using Premiere for awhile now but have always wondered what the optimum setup is for it. I mean where to keep files in relation to the drives and such.
    Basically my current setup is:
    I have 2 Internal Hard Drives. E: & F: (The guys who build the PC named the drives strangely) In fact I couldn’y load cinelook because it needed to go on the C: Drive. Anyway, I am using a Canopus DV Storm 2 Card. (Don’t know if this matters.)
    On Drive E: (Video Drive)
    On this Drive I keep All my Premiere projects.
    Basically I start a “Master” folder for each client .This is where the Premiere Project File sits. Then inside that folder I make another folder called Audio-Video Files. A second folder called AE Files. And a third folder called Slates & Tags (if Neccessary). Inside the Audio-Video Folder is another Folder called Voiceovers.
    On the F: (System Hard Drive)
    I keep a Photoshop/AE Folder, An Audition Folder & An Encore Folder. Inside each of these are seperate client projects. Any files that need to be accessed in Premiere get transferred to the E: Drive. If I use graphic files from Photoshop I make another folder on the E: Drive for those graphics.
    So Basically, is this an optimum setup? Should the Premiere Project File be with the video files? Does it really even matter? I ask because I am just trying to get the best/fastest response from my setup and have always wondered if I am doing something wrong.
    I used to work on a Turnkey Avid Express w/ Meridian Board and that had a specific setup in regards to only keeping video files on the External Drives and also no defragging of the video drives as well. Is Premeire like that at all? Should I defrag my E: Drive regularly with Premiere? (Currently I do).
    Anyway, thanks for looking at this and giving any response. I am not having any real issues so to speak but want to make sure that I am getting the most out of the system.
    Thanks.
    Chris Holland
    Chris Holland replied 20 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
