Activity Forums Creative Community Conversations Optimum configuration for iMac i7 setup with Final cut X and external drives
  • Optimum configuration for iMac i7 setup with Final cut X and external drives
    Posted by Joshua Haschke on May 17, 2011 at 8:07 pm
    Hello,
    I am currently filming a documentary movie filming on 3 types camera and media: Canon XH 1a (HDV at 24), Sony NEX 5 (Full 1080HD avchd) and iphone 4 (720p). I will be editing with Final Cut Pro X once it hits the market.
    My machine is an iMac 27″ i7 3.4, 1TB internal HD, 16G Ram and AMD Radeon HD 6970M with 2G VRam. I also have a WD 4TB external and a 500G WD External HD. i plan on getting another 4TB once the first 4TB fill up.
    What is the optimum configuration to handle all this mix media footage with these HDs with Final Cut X in order to make the most of this hardware? Raid or no Raid?
    Thank you so much
    Cheers,
    Haschke
    iMac 27″ i7 3.4, 1TB internal HD, 16G Ram and AMD Radeon HD 6970M with 2G VRam, WD 4TB external and a 500G WD External HD
    James Mortner replied 15 years, 4 months ago 4 Members · 5 Replies
  • Craig Seeman
    May 17, 2011 at 9:05 pm
    We probably won’t know for sure until we see how those H.264 files are handled but there are some things one should be looking for. Given the 64bit nature of things you may want to be open to getting more RAM since FCPX should be able to use it if you find any performance issues with your current amount.
    BTW is this a new Thunderbolt iMac?
    One question will be how HDV from tape will be imported since there’s been some debate about how tape will be supported.
    If H.264 genuinely handles well you may be able to avoid going to Apple ProRes which could save on hard drive space used.
  • Sohrab Sandhu
    May 17, 2011 at 10:19 pm
    [Joshua Haschke] “I am currently filming a documentary movie filming on 3 types camera and media: Canon XH 1a (HDV at 24), Sony NEX 5 (Full 1080HD avchd) and iphone 4 (720p)”
    An editor’s worst nightmare!
    Thank God you plan to edit on your own.
    2.66 GHz 8-core, ATI Radeon HD 4870,
    FCS 3, AJA Kona Lhi
    “The creative person wants to be a know-it-all. He wants to know about all kinds of things: ancient history, nineteenth-century mathematics, current manufacturing techniques, flower arranging, and hog futures. Because he never knows when these ideas might come together to form a new idea. It may happen six minutes later or six months, or six years down the road. But he has faith that it will happen.” — Carl Ally
  • Craig Seeman
    May 18, 2011 at 1:12 am
    Actually mixing those three formats will show what FCPX is truly made of. HDV tape input and two H.264 codecs. Nothing will match. This is a pretty good torture test project.
  • Joshua Haschke
    May 18, 2011 at 4:52 am
    Thanks so much…
    Yes its a thunderbolt iMac. Have I doomed myself from using three different cameras to catch 3 different angles? One reply said its a “nightmare..” ” nothing will match” because of the codecs. what are your thoughts? Is it still possible?
    Are we talking massive amounts of time? how would you set up the external 4TB drive? should i not set anything up until FCPX comes out? i have about 300 gigs of footage from the next 5 and iphone archived.. and the canon footage is still on tape.
    In addition.. its already maxed out at 16gigs of ram.. i guess that will have to do. i only got the iMac instead of the Mac pro to keep the whole project under a $10,000 budget…. perhaps this was a mistake.
    Thanks so much,
    Cheers,
    Thunderbolt iMac 27″ i7 3.4, 1TB internal HD, 16G Ram and AMD Radeon HD 6970M with 2G VRam. WD 4TB and 500G WD External HD
  • James Mortner
    May 18, 2011 at 2:59 pm
    “Actually mixing those three formats will show what FCPX is truly made of. HDV tape input and two H.264 codecs. Nothing will match. This is a pretty good torture test project.”
    One of the most intelligent things I’ve read in this forum. I wouldn’t especially want to be the editor on this as you will be in utterly uncharted waters.
    Best of luck to you sir !
