Activity Forums DaVinci Resolve optimizing my r3d playback?
  • optimizing my r3d playback?
    Posted by Jeremie Galan on May 9, 2016 at 1:41 pm
    With all the redner cache options and other stuff to optimize playback i m a little lost on how i should proceed. Heres my setup for a r3d weapon project ( 5k hd ).
    My rig is a i7 5960x ( 8 cores )
    Dual Titan-X
    64 Gb of ram
    media are on a RAID 0 ( blackmagic speed test says 1200Mb/s in read speed ).
    Obvisoulsy i’m trying to do 25 fps playback… and now it’s only getting 15/20fps with debayering set to half good.
    Timeline is hd 1920×1080
    any ideas on good starting block to getting better results?
    Regards
    J.
    Marc Wielage replied 10 years, 4 months ago 3 Members · 2 Replies
  • Michael Gissing
    May 10, 2016 at 3:00 am
    Presume this is a Resolve Pro (paid version not the free) and you have both Titan X cards enabled for CUDA.
    What are your settings for playback scaling presuming you are scaling the r3d to a timeline with different pixel aspect to the camera original. I have had no issue getting 25fps with a single Titan X playing 8:1 r3d scaling to HD from a Dragon.
    Should add my settings for scaling are for best playback and the final renders are to force best debayer etc
  • Marc Wielage
    May 11, 2016 at 3:16 am
    How does it work in 1/4-res good? That should be good enough for realtime playback, and you figure that’s roughly the equivalent of the HD screen on which you’re monitoring.
