Activity Forums Maxon Cinema 4D Optimizing causing mesh problems
  • Optimizing causing mesh problems
    Posted by Sean Kimber on December 19, 2016 at 7:27 pm
    I purchased an animated heart model from CG Trader. It works great, but I’m trying to highlight one section of the heart at one point. So, since it was a singular mesh, I disconnected the part I needed and put it on a separate layer. However, the heart’s animated using pose morphs. So, when I try to optimize the model and delete unused points, it causes major problems. Is there some way that I can fix this? Here’s the project.
    10881_heartatriumseparateforcreativecowc4d.c4d.zip
    Sean
    Sean Kimber replied 9 years, 9 months ago 2 Members · 2 Replies
  • Brian Jones
    December 20, 2016 at 7:48 pm
    pose morphs are like PLA as far as I know so changing point counts would be fatal I would think. Highlighting would be probably better done with textures
  • Sean Kimber
    December 21, 2016 at 2:37 pm
    Hi Brian,
    Thank you for your help! I was hoping to be able to make the highlight change in AE in case the client wanted a different color, etc. But, your logic makes complete sense…unfortunately.
    Thanks again!
    Sean
