Activity Forums Adobe After Effects Optimizing Adobe After Effects Performance for Complex Projects
  • Optimizing Adobe After Effects Performance for Complex Projects
    Posted by Chirs Root on June 29, 2025 at 12:10 pm
    What are the best practices for improving Adobe After Effects performance when working on heavy compositions with lots of layers, effects, and 4K+ footage? Are there specific hardware configurations, settings tweaks, or third-party plugins that significantly help with render times and playback lag? Also, how well does AE utilize multi-core CPUs and modern GPUs in 2025? Let’s share tips and setups that work!
    Joel Bellagamba replied 1 year, 1 month ago 3 Members · 2 Replies
  • John Martin
    June 29, 2025 at 1:37 pm
    Hey Chirs i recorded a 15 minute guide helping you optimize AE for performance + 2 methods to make proxies (one standard, one more powerful more complex), Enjoy! 🔥
    https://youtu.be/foYPfDKBSLs
    Hardware wise, make sure your processor has at least 16 physical cores running at 5hgz + minimum 64gb of ram, keep your projects at 8bpc and enable (cuda) if that’s available. Good luck and let me know if you like the help!
  • Joel Bellagamba
    July 7, 2025 at 10:10 am
    To speed up After Effects for complex projects:
    Use multi-frame rendering increase RAM use proxies precomps GPU effects and lower preview quality.
