Activity Forums Adobe After Effects Optimized rendering: 8 core, 16GB RAM, Nucleo Pro
  • Optimized rendering: 8 core, 16GB RAM, Nucleo Pro
    Posted by Andy Taplin on November 29, 2007 at 1:34 pm
    Hi All
    I can’t seem to get my MacPro to use most of its processor power (according to the activity monitor) when rendering from AFX CS3 8.
    All 8 cores are being used but on simple renders only about 20-30% of the capacity.
    The AFX multiprocessor renders are also slightly faster than Nucleo Pro which surprises me. And there appears to be no difference between normal and maximum in the performance level options for Nucleo. I’ve tried fooling around with the percentage of RAM allocation – no real difference at 60,100 or 120%. Am I missing something?
    If it’s a tricky render more processor power is used but I’d like the option of maxing out the Mac even on simple renders.
    Thanks for your help.
    Andy
    Andy Taplin replied 18 years, 9 months ago 5 Members · 7 Replies
  • 7 Replies
  • Itamar Kool
    November 29, 2007 at 2:36 pm
    I have about the same experience as you do. Also starnge thing is that when I do a RAM preview in Nucleo Pro 2, the green bar stops right before the end and I have to hit shift-space bar again to really see the RAM preview
    Kool En De Anderen
    MAC Pro 8 core/Kona LHe/Apple FCS 2/Adobe PPCS3/Huge fibrechannel
    http://www.koolendeanderen.nl
  • Andy Taplin
    November 29, 2007 at 6:11 pm
    Hmm… I’ll try Nucleo and see what they say.
  • Jason Milligan
    November 29, 2007 at 6:52 pm
    Perhaps I’m wrong, but I doubt anyone can configure their machine to always max out its resources for every render. Some renders aren’t going to need as many resources to compute their data. Processors and RAM aren’t the only variable when rendering either. Your hard-drives can only spin and write data so quickly (keep in mind your system is also probably using hard-drive space as a scratch disk also). There will be a threshold where one (be it RAM, processors, hard-drive, graphics card, etc.) cannot keep up with another.
    That being said, I imagine someone may have some tips on maximizing your settings to get the most out of your resources. I’m still trying to figure out the best configuration for my computers also.
  • Joey Burnham
    November 29, 2007 at 8:45 pm
    Hi There,
    I have basically the same system as you. I could be wrong about this, but as far as I know each core uses 1 gig when multiprocessing. So you need to adjust your percentage of use to a number that gets you less that 1 g. Mine is set to %30.
    BUT, I have found that for simple renders it is much better to keep multiprocessing off. It takes longer just for it to fire up all the cores than the initial render would have taken in the first place.
    Good luck,
    Joey
  • Andy Taplin
    November 30, 2007 at 9:09 am
    Thanks All
    I guess I though I had reached computer power nirvana with an 8 core and all that RAM! – still I can run 4 or 5 apps at once now which is a big productivity boost.
    I’ll also try dropping the RAM allocation.
    Andy
  • Reggie Spires
    December 1, 2007 at 11:18 pm
    What is the exact componets to your machine … I am fixing to build a new machine
  • Andy Taplin
    December 3, 2007 at 5:40 pm
    MacPro 3GHZ 8 Core
    16GB DDR2RAM
    ATI Radeon X1900 XT
    2x 500GB internl drives
    3TB G-Tech G-Speed eS RAID (5)
