Activity › Forums › Maxon Cinema 4D › optimized PC requirements for Cinema 4D
  • optimized PC requirements for Cinema 4D
    Posted by Hamid Rohi-bilverdy on January 11, 2012 at 5:55 pm
    Hi forum
    Before I go out and buy Cinema 4D, I want to make sure that the next computer I am buying is more than suitable and that the program can take fully advantage of the computer.
    The computer I am buying has these main specifications:
    CPU: Intel® Core™ i7-2600 4×3,40GHz (Turbo 3.80GHz)
    RAM: Kingston 16GB DDR3-1333 RAM
    GRAPFIC CARD: nVidia Quadro 2000 1GB PCI-E
    So in terms of CPU, RAM and Grapfic card, are these hardware items suitable and enough??
    Looking forward to hear from you
    Best regards Hamid
    Jey Kumar replied 14 years, 8 months ago 3 Members · 2 Replies
  • Philip White
    January 11, 2012 at 7:21 pm
    You’ll be fine with that set-up in terms of CPU & RAM
    I’m most likely wrong, but RAM for Rendering (or at least extensive amounts of it) won’t make leaps and bounds of difference compared to a more powerful CPU / GPU…
    I’m working on a Macbook Pro (Which has also had it’s internals replaced / modified etc) and it runs quite nicely – Of course, I’m rendering things for corporate animations and not something like a Pixar film…
    You should be fine however – but someone else may give you a better idea…
  • Jey Kumar
    January 17, 2012 at 2:00 pm
    That should be sufficient.
