Activity Forums Adobe Encore DVD optimized encoding settings?
  • optimized encoding settings?
    Posted by Dean Walsh on January 9, 2006 at 10:55 pm
    hi
    ok i have video files taken from my sony DV cam and they’re about a gig in size each.
    I was wondering how i can burn these to disk using encore and/or Premiere pro whilst retaining the highest quality possible and making the aspect ratio fit to PAL television.
    What settings should i be using to get the best?
    thanks ppl!!!
    Tim Kurkoski replied 20 years, 8 months ago 2 Members · 3 Replies
  • Tim Kurkoski
    January 10, 2006 at 3:09 am
    1 gig is about 5 minutes of DV video. Is that how long each of the files are?
    At that length, you’ll have no problem using the max bitrate setting for DVD-legal MPEG-2 files. But for compatibility with all DVD players, I’d recommend you top it out 7000 Mbps. It’ll still look great at that rate.
  • Dean Walsh
    January 10, 2006 at 12:38 pm
    should i use automatic transcode settings are select custom settings.
    Also will the video fit my PAL tv screen when using these settings?
    thank you!
  • Tim Kurkoski
    January 10, 2006 at 8:27 pm
    The automatic settings will be fine. Is your DV camera a PAL camera? If so, then yes.
