Activity Forums Adobe After Effects Optimize Renser Speed by understanding comps, layers, expressions and effects
  • Optimize Renser Speed by understanding comps, layers, expressions and effects
    Posted by Remi Monedi on December 30, 2018 at 2:26 pm
    I found many posts about render settings, but what I’m really interested here is regarding compositions, layers, expressions and effects organization. I’m making more and more complicated projects and where they are very organized, I’m not sure they are very optimized for render/preview speed.
    SO I have several questions about render speed improvements (even the slightest) :
    1. What is faster : One comp with a lot of layers OR One comp with a few precomps?
    I guess it’s the first one but I read in some cases, a precomp is actually the faster way to render especially if it rasterizes a huge layer for instance. Maybe there are other cases.
    2. What is faster : A lot of layers with few effects on them OR One layer with a lot of effects applied to it?
    3. How an expression can slow down the render speed?
    Is it the length of it or specific expressions?
    4. Let’s take a layer with a Turbulent Noise. To “deactivate” it, I have two options : Set the Effect opacity OR the Layer opacity to 0% . Is there a difference renderspeed-wise? Another example with the Posterize effect, if I set it to 255 (its maximum value), is AE still calculating it?
    I often ask myself if effects set not to affect their layer (with Amount, Opacity set to 0%, Blend with original set to 100%, …) are still calculated by AE, and taking a bit of render time, or if AE ignores them.
    Have a nice day!
    Remi Monedi replied 7 years, 8 months ago 1 Member · 1 Reply
  • Remi Monedi
    January 13, 2019 at 7:11 pm
    Hi everyone, sorry for the late reply and Happy New Year!
    Thank you Dave for your answer! Actually I should have added the mention PREVIEW SPEED with RENDER SPEED in this Thread title. This is why I was asking very specific questions. I want to find the best/fastest way to work, preview and render complex projects in AE.
    To help me answer it, I finally decided to make some simple test in AE, here are my conclusions :
    1. BECAUSE even set to its “dead” value, an effect takes time to render,
    (for instance a Displacement Map effect with Horizontal and Vertical Displacement value set at 0%)
    > THE FASTEST WAY to “deactivate” an effect is to set the opacity of the ADJ layer to 0% (if it’s on an Adjustment layer)
    > OR the other way is to set the effect opacity (in Compositing Option) to 0%
    2. 1 ADJ LAYER with a X EFFECTS is FASTER than X ADJ LAYERS with 1 EFFECT (each) which is also FASTER than X COMPS with 1 ADJ LAYER with 1 EFFECT.
    3. Expressions are calculated each frame and makes preview/render slow
    > Use keyframe if possible : Convert Expression to Keyframe
    > Avoid Math function expression if possible
    > Use a script
    > Make expression more efficient (How ?)
    If there are simple tricks to make expression more efficient, I’m interested!
    Have a great day
