Activity Forums Adobe Premiere Pro Optimising playback in Premiere CS4 – I’m used to FCP!
  • Optimising playback in Premiere CS4 – I’m used to FCP!
    Posted by Ian Galloway on September 9, 2010 at 10:40 am
    Hi there
    I’m using Premiere CS4 on an iMac (2.4Ghz Core 2 Duo/4Gb RAM). I’m working with H264 footage shot using an EOS 550D. The footage is on an external 7200rpm G-Disk connected via FW800.
    I’m using Premiere for the first time in a while – I’m trying to switch over from Final Cut Pro.
    I’m doing an edit to music. I have my sequence settings set to the same thing my footage is – H264 1920×1080. When I try and play back the sequence in the timeline, things go out of time, the footage lags, the computer struggles to keep up with itself. Even if I render the footage so that it displays with a green bar, it won’t play back without lagging or going out of time. The only way I’ve found to get around this is to change my Video Preview settings to a low-quality codec like DV or Graphics.
    I know that if was editing in Final Cut, it would play a lower quality ‘preview’ version while i edit so that the edit can be seen in time with music, and it would only require me to render if I had effects on the clips (which I don’t) – does Premiere have a similar feature to this? It seems very silly to have to render everything into a different (and very bad) codec every time you want to actually see something in time!
    Kevin Monahan replied 15 years, 12 months ago 2 Members · 1 Reply
