Activity Forums Adobe Premiere Pro optiminzing stills in adobe preimere pro 1.5
  • optiminzing stills in adobe preimere pro 1.5
    Posted by Leslie Barker on May 8, 2009 at 5:54 pm
    Hi ike you solved a problem for me a while back which I appreciate very much but now another problem. i am using adobe preimere pro 1.5 to build a slide show when I play it in adobe it plays fine but when I encode it and put it in encore the first picture is with a curtain transition it plays fine but when it goes to the 2nd pic with an iris star transition it jumps to pic 3 all the rest of the pics after that play fine. I have turned off optimize stills in the project manger and also in the settings box when I encode it. What am I doing wrong I have use this program for several years and never had this problem. Can you help me again.
    Thanks Mike
    Hi I am trying to capture live video via firewire to adove preimere but when i press pause it stops the capture and you have to title the capture clip and restart capture is there a key or button that will allow you to pause and then continue on capturing in one session? Thanks for any hilp
    Leslie Barker replied 17 years, 3 months ago 1 Member · 1 Reply
  • Leslie Barker
    May 8, 2009 at 9:50 pm
    Hi has anyone had this problem I have a slideshow of still pics in adobe preimere with a title at the start, when I encode it for encore and import it into encore the title plays then the 1st pic plays after that it skips the 2nd pic and goes directly to the 3rd pic. I have optimize stills disabled in project settings and also when I encode it.I have had this problem before now it is back. I am using adobe preimere pro 1.5 and Encore. I would greatly appreciate any help
