Activity Forums Apple Final Cut Pro Legacy optimal stabilizing and changing clip speed
  • optimal stabilizing and changing clip speed
    Posted by Annu Lilja on March 31, 2009 at 10:48 pm
    HI,
    I have Red footage that is shot both 6 fps and 12 fps for the motion blur effect, and I need to slow the clips down to normal speed. The clips are shot from a moving vehicle and they are very bumpy. I’m guessing that the only way to rescue the clips would be to stabilize them – does anybody know the best way to do that? We want to create a subtle motion blur if possible, but the clips look pretty psychedelic the way they are, or when I try to slow them down to normal speed. Do you think we have to reshoot? Actually the 12fps clips are pretty OK, but still need to be stabilized.
    Annu
    John Fishback
    replied 17 years, 5 months ago
    2 Members · 1 Reply
  • John Fishback
    April 1, 2009 at 3:19 am
    In FCP6 try Smoothcam. AfterFX has image stabilization and there are others out there – try lyric.com. I have no idea which would be best for your situation. There are probably demos you can download,
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870
    ATTO ExpressSAS R380 RAID Adapter, PDE Enclosure with 8-drive 6TB RAID 5
    24″ TV-Logic Monitor
    Final Cut Studio 2 (up to date)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
