Activity Forums Apple Final Cut Pro Legacy optimal settings for capturing from digibeta?
  • optimal settings for capturing from digibeta?
    Posted by Clay Sparks on April 25, 2005 at 7:47 pm
    does anybody have an opinion on what the best settings to get the best quality from a digibeta. so far i’ve been seeing a pretty questionable result. i’ve been using blackmagic 8-bit.
    Shannon Brame replied 21 years, 4 months ago 2 Members · 1 Reply
  • Shannon Brame
    April 25, 2005 at 7:52 pm
    The difference between the image quality of BlackMagic’s 8 or 10 bit is neglegible. If you are an avid user, think of 8 bit as 2:1 and 10 bit as 1:1. What sort of problem are you having, what decklink card do you have, and are you using a broadcast monitor?
