Activity Forums Adobe Premiere Pro Optimal scan resolution for 1.5
  • Vince Becquiot
    October 9, 2007 at 12:38 am
    If you are not doing any zoom or pans, a 648×480 (square pixels) cropped image will give you a perfect fit in a 4:3 frame. If you plan on zooming in, add that zooming percentage to the resolution accordingly.
    Vince
  • Jeff Brown
    October 9, 2007 at 12:50 pm
    I’d say the optimal scan rez is however high you can afford to get it, up to 4K. You can always downsize the scans later for a particular use, such as SD video.
    -jeff
