Activity Forums Apple Final Cut Pro Legacy Optimal Hard Drive Tips
  • Optimal Hard Drive Tips
    Posted by Mike Cooper on May 14, 2007 at 12:31 am
    1. Are there any real performance issues with capturing to the same drive as the drive that has FCP an Mac OS installed?
    2. How often should a drive that is being used to capture and edit video be
    defraged? Does it make much difference performance wise to have it defragged?
    3. Are there any other general tips for keeping a drive for video running optimally?
    Thanks in advance!
    Tom Meegan replied 19 years, 4 months ago 2 Members · 1 Reply
  • Tom Meegan
    May 14, 2007 at 9:58 am
    1. Yes.
    If you are using DV, you will probably get away with using one drive for everything, but it is akin to driving without a seat belt. If this is a hobby, and you can tolerate some risk when it is weighed against the cost savings
