Optical Stabilizer will not analyze clip
Posted by Gene Borman on November 6, 2011 at 4:59 pmHi, I,m running a trial version of BCC Optical Stabilizer in Vegas Pro 10. When I apply the FX to a clip it will load properly but clicking the analyze button does nothing. I have W7 and am using .m2t and .mts HD clips.
Gene Borman replied 14 years, 10 months ago 3 Members · 5 Replies -
Mike Hinkel
November 7, 2011 at 12:09 amIt appears that Boris and Vegas really need to tie the knot. I have the same issue with VP11. Hoping for a solution before there are any more upgrades..
Gene Borman
November 11, 2011 at 4:58 pmHi Mike, I upgraded to Mercalli V2 plugin for Vegas and that solved my problems. I now get smooth non (less) cropped results when stabilizing the helicopter footage. Just one “heads up” after loading the plugin you have to go to add effect rather than right clicking which brings up default V1 plugin.
Mike Hinkel
November 11, 2011 at 6:47 pmThanks Gene, I’ll look into the MercalliV2. I was hoping for a response from the team at Boris who is supposed to be working on this from a previous post of mine. nothing is more annoying than paying for a program and it does not function as advertised.
Dave Stern
November 24, 2011 at 3:52 amyou know what’s odd is that all of a sudden, mine won’t analyze either … I did update recently my nvidia driver but that’s about it .. vegas 10 on XP SP3, BCC7. My analyze button worked a few weeks ago, now it won’t analyze .. I’m stymied – not sure what it could be that broke this .. any suggestions appreciated! it’s very odd .. I was going to uninstall and re-install BCC,not sure if that will help.. weird stuff..
Gene Borman
November 25, 2011 at 2:06 pmLuckily I had a trial version of Boris so I’m not out the money.
Plus Boris has not responded. So I’m sticking with MercalliV2 which is working great.
