Activity Forums Boris FX Optical Stabilizer does not work with APrem CS5,
  • Optical Stabilizer does not work with APrem CS5,
    Posted by Jaap De jong on October 29, 2011 at 2:24 pm
    Optical Stabilizer fine with AfterEffects CS5 but does not work with APrem CS5,although the effect appears in the Effect Control Window.
    Remarkable: In AE the Effect Control comes with “corner symbols, circle with crosshairs” and in Prem not.
    Jeremy Ellis replied 14 years, 10 months ago 2 Members · 1 Reply
  • Jeremy Ellis
    October 31, 2011 at 4:20 pm
    Hello,
    If you’re referring to when you select “Setup Region”, in order to see the circles with the crosshair you must goes back and select the effect. If you don’t understand, please email me at jeremye@borisfx.com and i will provide you some screenshots.
    Thank You
    Jeremy
    Boris Support
