optical flow slow 50% with 23.976 footage
Posted by William Busby on October 20, 2012 at 3:42 amBCC 8.03, Avid MC 5.5.3. / How in the heck can one use Optical Flow for 23.976 footage smoothly? I have to slow a clip down to 50%, I have the input set to progressive and the frame rate of the source set to 23.98. It seems every 7th frame from the render is duplicated twice which obviously will look like poop.
Any ideas would be greatly appreciated.
William Busby replied 13 years, 11 months ago 2 Members · 4 Replies -
Peter Mcauley
October 22, 2012 at 12:02 pmHi WIlliam,
I’m not sure why you’re seeing that result and I’ll take a look this morning to see if we can reproduce the issue on our systems. In the meantime, you should be able to set the Blending Mode to Frame Blending Only and continue working. If the problem persists even after you have changed the Blending Mode, then try using BCC Velocity Remap instead of BCC Optical Flow while we investigate the issue.
Peter.
Peter Mcauley
October 22, 2012 at 3:28 pmHi WIlliam,
We just tried reproducing the problem that you described using our MC 6x systems with BCC 8 and for us the BCC 8 Optical Flow filter operates smoothly, just as expected on both platforms.
Next, we’ll move back and check on an the older MC 5.5 systems to see if it’s related to using the previous version of Avid Media Composer.
Stay tuned.
Peter.
Peter Mcauley
October 22, 2012 at 3:57 pmHello again William,
Further investigation into this issue. We’re seeing something unexpected but slightly different than you are with the Optical Flow filter (in MC 6) at 50 percent in a 23.978 project.
What we are seeing is that the Optical Flow filter appears to be missing a frame during the render. This seems to be happening only once in the render and not every 7 frames as it is on your system.
With that, we’ll open up a support case and attempt to resolve the problem. In the meantime, as I suggested earlier, for clip retiming effects, you might want to use BCC Velocity Remap, which does not exhibit this problem.
Thank you for letting us know about the problem – when I have more information regarding this issue, I’ll share it with the list. .
Peter.
William Busby
October 22, 2012 at 8:06 pmThanks Peter. I got through it doing something similar to what you had suggested.
I’ve noticed the 1 repeat frame you mention only in 1080i & 60i projects before and it always seems to be on the 14th or 15th frame (can’t recall). However, I just tried a 50% render on different 23.98 clip as a test and it was smooth but saw that 1 repeat frame as well but it repeats twice.
There must be something funky with the original clip that consistently repeated every 7th frame in the render I mentioned.
