Activity Forums Boris FX Optical Flow not flowing…
  • Optical Flow not flowing…
    Posted by Michael Peele on December 16, 2010 at 2:12 am
    Aloha,
    I am having an issue with BCC6 Optical Flow in FCP 7.0.3 on a ProRes 422 1920×180 29.97 timeline. We have AJA Kona LHi cards in the systems.
    I get a ONE slight skip in the clip towards the beginning (1st couple of seconds). Almost like the clip was moving forward fine, goes back a frame, and then moves on again. After the jump, playback is flawless.
    My procedure for is to create a slug of the same duration as my source clip. I add the Optical Flow filter to the clip. I add my source clip to the source layer of the effect (dragging it from timeline). Set my velocity (and any pertinent field/frame rate settings). Hit render. Wait.
    At first I thought this was related to differing source clip/sequence settings, but now I see that all of my optical flow renders have this jump/skip/glitch. At least on ProRes timelines, I haven’t tried others yet.
    Other than that, the renders look awesome. I have tried a bunch of different setting to alleviate the problem, but no luck.
    Any ideas?
    Mahalo,
    Mike
    P.S. – Also fun is DVCPROHD 720p60 as source for Optical Flow on a ProRes 29.97 timeline – 100% velocity is 50% speed on render. I guess that makes sense. Kinda. Didn’t notice a frame jump in that render, I would have to check again. Maybe the issue is field related (DVCPROHD source was progressive).
    Michael Peele replied 15 years, 8 months ago 2 Members · 2 Replies
  • Boris Yamnitsky
    December 20, 2010 at 5:13 am
    I can’t explain the jump. One suggestion I have is to try BCC7 and see if that works better. We mostly test with ProRes HD so I would not expect any problems.
    Boris Yamnitsky
    BorisFX
  • Michael Peele
    January 16, 2011 at 2:20 am
    I have upgraded to version 7 and I am still having the issue – I created a newer post in this forum with more info.
    Thanks for your help
