Activity › Forums › Apple Motion › Optical flow background artifacts
Posted by Alfred Guzzetti on June 30, 2008 at 9:20 pmI exported an HDV clip from FCP to Motion to slow it down 25 per cent using Optical Flow. When a foreground figure crosses in front of a bright vertical pole in the background, the pole distorts. Is there a solution to this kind of artifacting?
Alfred Guzzetti
Mac Pro Quad 2.66GHz 4GB RAM
Intensity Pro card
OS 10.4.9
FCP 6.0Alfred Guzzetti replied 18 years, 2 months ago 3 Members · 6 Replies -
Noah Kadner
July 1, 2008 at 12:20 amMight be related to HDV. I’d export it to ProRes first, then run with optical flow.
Noah
My FCP Blog. Unlock the secrets of the DVX100, HVX200 and Apple Color and Win a Free Letus Extreme.
Now featuring the Sony EX1 Guidebook and Sound for Film and TV.
https://www.callboxlive.com -
Alfred Guzzetti
July 1, 2008 at 3:17 pmMany thanks. I tried this but Motion doesn’t seem to have ProRes as a Project Property; so I tried DVC 100 but got the same artifacts.
Alfred Guzzetti
Intensity Pro card
OS 10.4.9
FCP 6.0 -
Noah Kadner
July 1, 2008 at 3:47 pmConvert the HDV source file to ProRes in FCP or in QuickTime Player, then import into Motion and apply the effects.
Noah
Alfred Guzzetti
July 2, 2008 at 12:21 amThanks again. I tried this but it led to the same artifacting. I’ll try capturing the HDV clip using ProRes via HDMI (rather than doing a software conversion) and report back.
Alfred Guzzetti
Intensity Pro card
OS 10.4.9
FCP 6.0 -
Adam Wilder
July 9, 2008 at 11:14 amI don’t think this is a codec problem. What’s most likely happening is that your subject is crossing this pole fairly quickly and what you’re seeing is the result of the blending created by the Optical Flow algorithm. For example, take a look at this clip showing the results of optical flow.
https://www.metacafe.com/watch/1270539/super_slow_motion_optical_flow_retiming/
There are two areas where I think you’ll see the type of artifact you are describing. The first is at about 52 seconds. Look at the arm. The second is at about 1 minute, when the frisbee crosses over the logo on the t shirt. In both cases you have significant changes between a short number of frames, and now you’re trying to blend and stretch the data.
Lets say that in real time, there are 3 frames for the frisbee to cross the logo on the shirt. Frame 1, before it crosses, Frame 2, covering the logo, and frame 3. When you slow that down 25%. you’re now generating 12 frames and only three of those are “real” the rest are interpolated and since you don’t have a lot transition information (example: 2 more frame where the frisbee partially covers the logo) in those areas you sometimes get these artifacts. Optical flow is working correctly with the information it has.
The only way you could maybe minimize the results would be to use a different speed, faster or slower (oddly enough sometime slower fixes the problem). You could also try duplicating the clip, use a different frame blending and mask it over the optical flow clip.
Alfred Guzzetti
July 17, 2008 at 12:57 amI think you’re right. I was afraid that this might be the case. I wonder if Twixtor’s algorithm avoids this type of artifact.
Many thanks for the workaround suggestions.
Alfred Guzzetti
Intensity Pro card
OS 10.4.9
FCP 6.0
