Activity Forums Apple Motion Optical Flow
  • Optical Flow
    Posted by Salah Elfalahi on March 19, 2010 at 12:19 pm
    Hi All
    I shot one clip (test shot for later project) using my EX3 (720p50). in final cut 7 i sent one clip to motion 4 just to slow it down using Optical Flow (30%). the result wasn’t pleasant as i got some kind like a goest or mirage behind the moving subject. I trashed the preferences, but that didn’t change anything.in the clip: I’m moving my daughter up and down while camera locked down on tripod. the clip is 14sec long and took 3 sec to finish processing.
    Salah
    Alexander Kallas replied 16 years, 6 months ago 4 Members · 4 Replies
  • Zak Peric
    March 19, 2010 at 1:46 pm
    Hi Back,
    I do not think you did anything wrong, it is just that some footage does this when a optical flow is applied. You just have to tweak settings to try to get that corrected. Best of luck…
  • Arnie Schlissel
    March 19, 2010 at 2:14 pm
    I think that’s kind of typical for long-gop formats.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Salah Elfalahi
    March 19, 2010 at 6:10 pm
    Thanks for the replies
    I’ve had optical flow added in few deferent formats ( DV,HDV,HD) and in deferent ways (subject moving fast or slow, camera fixed or moving…) ..I always have the same result, the goest like behind the moving subject !!
    Salah
  • Alexander Kallas
    March 21, 2010 at 10:03 am
    Convert to ProRes first.
    Cheers
    Alexander
