Activity Forums Adobe After Effects Optical Flares
  • Optical Flares
    Posted by Anders Lilkaer on August 31, 2010 at 11:39 am
    Hello,
    I have two compositions. Each containing quite a few instances of optical flare plugin from Video Copilot.
    Now, i want to make a transition of the two comps, in a new composition – But, when the two comps (with multiple OF plugins) overlap, they make a terrible noisy image!
    The other solution is to export each composition with an alpha channel, aaand I’ve also tried that.
    When I make the two compositions overlap, they also create a very disturbing image… it doesn’t look exactly like the other problem at all, but very bad too.
    How can I make these two compositions cointaining Optical Flare plugins, overlap with transparency without faulty images??
    Much appreciated!
    Cheers,
    Anders
    Lsp Cui replied 8 years, 7 months ago 3 Members · 8 Replies
  • 8 Replies
  • Walter Soyka
    August 31, 2010 at 3:52 pm
    How are you transitioning from one comp to the next?
    Can you post a screenshot of the noisy output you’re seeing?
    Walter Soyka
  • Anders Lilkaer
    August 31, 2010 at 4:11 pm
    Yes – https://lilkaer.dk/OF_error.png
    What you see is essentially two splines generated by trapcode particular, that has lights tracked to the Emitter-light. When they overlap, the error occurs.
    As mentioned above, if I export them as alpha channels and then try to overlap eachother, another bay error occurs.
  • Walter Soyka
    August 31, 2010 at 4:37 pm
    Has one of the comps been repositioned (thus revealing an edge?)
    Or have you tried disabling GPU rendering within the plugin?
    Walter Soyka
  • Anders Lilkaer
    August 31, 2010 at 4:50 pm
    No, the comps are exactly at center both of them.
    And I’ve tried with and without GPU rendering….
  • Anders Lilkaer
    September 1, 2010 at 12:56 pm
    Anyone? :S
  • Anders Lilkaer
    September 1, 2010 at 1:08 pm
    Allright! The problem occurs when working in 32bit! 16 bit works fine 🙂
  • Walter Soyka
    September 1, 2010 at 2:55 pm
    Huh. Good to know! Thanks for posting back with the solution.
    Walter Soyka
  • Lsp Cui
    January 25, 2018 at 4:02 am
    After so many years, I encountered the same problem here.
    The comp started having very bad noise after I installed the Video Pilot Optical Flare. I was Googling around and your post was my best chance to solve the problem.
    My problem was different from yours. The color depth of my AE template was in 16 bit by default, so I thought it wasn’t the problem. At the end when I was running out of choices I tried 32 bit and it magically worked!
    If anyone out there Googling the same problem. Go to File → Project Setting → Color Setting → Depth and try different value of depth.
