Activity › Forums › Adobe After Effects › Optical Flares Problem
  • Optical Flares Problem
    Posted by Jorge Rosado on September 28, 2011 at 3:32 am
    I’m having a problem with Optical Flares, I apply the effect to a solid and nothing happens. For example, if I make a new a new white solid and apply the effect, it doesn’t change, it stays a white solid. How can I fix this?
    Matthew Keane replied 15 years ago 3 Members · 4 Replies
  • Adam Taylor
    September 28, 2011 at 9:12 am
    how do you expect to see a lens flare on a white solid?
    Try it on a black solid, with the black solid set to screen transfer mode
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
    My YouTube Animations Page
  • Jorge Rosado
    September 28, 2011 at 4:28 pm
    I used White as an example i’ve done it with black also. I just tried again doing what you said, Black solid screen transfer mode and still nothing. Here’s a screenshot of my settings
  • Matthew Keane
    September 28, 2011 at 8:37 pm
    It doesn’t look like you have any lights in the scene. Since Optical Flares reacts to AE light layers, that might be why you’re not seeing anything.
    Matthew
  • Matthew Keane
    September 28, 2011 at 9:17 pm
    Oops, spoke too soon! I’d only ever used OF with lights but, as you’ve found, you can also use manual positioning. I’ve just set up a test project as per your screen shots and it’s working for me. Have you tried using a different OF preset, to see if that works? The only difference that I can see is that I don’t have a compressed .mts file for the background layer, but I’d be surprised if that was the answer.
