Activity Forums Video Copilot optical flares crashing AE
  • optical flares crashing AE
    Posted by Coulter Mitchell on October 21, 2010 at 5:41 pm
    Hello!
    I recently purchased video copilots optical flares. The problem I’m having is every time I apply optical flares to a solid in after effects cs4 and hit the options button under the effects tab to bring up the optical flares interface it crashes and I get the message: After effects error: Crash occurred while evoking effects plug-in “optical flares”
    I would appreciate any help and thank you in advance!
    Nathan Mcneil replied 15 years, 3 months ago 2 Members · 1 Reply
  • Nathan Mcneil
    May 28, 2011 at 4:52 pm
    I realize this is an old thread but hopefully this reply will help someone somewhere.
    During the time of CS4 an upgrade that helped fix this problem was released from Video Copilot, it’s available from the website.
    Other things to try are disabling your GPU rendering (this is found under the options for your Optical Flares in File > Preferences) and deleting a preset called Evening Sun.ofp from Optical Flares Presets > Lens Flares.
    I had the same issue and doing all of this corrected it. If you purchased the Optical Flares bundle, and still have problems, e-mail tech support, they got back to me even on the weekend.
    Nate
